Hello. I've seen someone that has went through this before. they swapped a new ECU and the car started again. So you'll likely will be needing a new ECU.
Hate to ask but...
Are you sure the timing belt is in one piece?
Take off the distributor cap, remove the center wire so you're not throwing sparks, crank the engine and see if the rotor turns. If not, the timing belt is done.[/QU
Hi, we checked this and it was spinning.![]()
---Hi, I am thinking this might be the problem. rockauto has one for not too bad, so I think Ill be getting one soon. Just curious, if the ECU is bad, would it be able to still attempt to start?Hello. I've seen someone that has went through this before. they swapped a new ECU and the car started again. So you'll likely will be needing a new ECU.
