91 acura engine light
814 Views 3 Replies 3 Participants Last post by  mrmiami
I had the erratic idle problem so I cleaned the IACV and still had the problem so I read on a post on here to turn the fast idle thermal valve clock wise and it fixed the erratic idle problem but now when I crank car about a block into the drive the engine light comes on anyone have a solution thanks
1st get a the code for cel once you get that it will tell you what the problem. But I'm sure once you back up the screw a lil bit it may fix the problem.
