press the center of the housing from the rear..it will move forward, then you just pull to YOUR right and outjason520 said:After I unscrew it, how do I pop out the lights? They are indented into the bumper!
UGH! Whoever would have known this would be so frustrating???
I found the screw and unscrewed it, and the lights seem to be just sitting in place now, but I don't know how to get them out!
Jason, on the 91-93 Legends (I'm speaker for Coupes, so Sedans may be different) the foglight ocver needs to be removed. To remove the foglight cover, you remove teh phillips screw located under the foglight cover. However, for the 94-95 Coupes, there is an access hole right near the top corner of the foglight cover that leads straight to the phillips screw holding in the bumper light. So it really depends on what year Legend you have. I remove my bumper light using this access hole all the time.jason520 said:Well they are installed, the job is done. I just had to get some balls and rip off the fog light cover. I don't care what anyone says, the job is impossible without doing so, at least on my car.
Peace,
J520
I agree you could probably unscrew it using the hole, but there is no way to pop the light out afterwards! The problem now is my foglight covers are not staying on. They are a ***** to get in!ChrisK said:
Hmm, yours must just be a little tighter then mine or some of the rest of ours. My bumper light seems to pop out with little problems, Even the aftermarker ones from APC pops out Okay, but only hafter I shaved down the slide tabs a bit, as it was very tight when I first got them.jason520 said:
