Re: Re: Re: 94 L 6speed value?
MkIIMike said:
Well, what do you think above average $$$ is? He didnt do the service either. Why is a clutch so expensive?
Thanks man!
Oops.
The clutch is that expensive because the actual CLUTCH costs like $400-600 dollars.
Plus the work to actually put it in, ranges from 400-600 bucks.
So it can be like 800-1100 dollars just to put it in.
The good thing is, that it tends to be really dependable. At that point, however, I'd put in an aftermarket Centerforce of Clutchmasters clutch, for improved "grab"...
But then again, you may have to change it in another 50k. It's hard to tell. Just the luck of the draw, I guess.
