My car used to whine like it had a supercharger when my Air Conditioning was ON. Being that it is winter, I haven't had a problem with it, it used to bother the heck out of me.
So end of last week I was at a stop light and had my tunes turned down and I noticed that I heard this strange sound coming from my engine. So I pulled over, and popped the hood, and the sound seemed to have been coming from the belts. They sounded loose, but when I had my boyfriend check it, he said that it was the a/c compressor, and that I needed a new one. Being that he is a Nissan driver, I figured I'd ask the Acura guys/girls who might have experienced the same problem, before I go to the dealer and have them break my wallet. The sound doesn't seem to get louder no matter what speed I am going, and if I rev it up it doesn't really change neither. If I do indeed need a new a/c compressor, anyone know if its an easy job to do? Or is it worth getting it done by the mechanic?
Any ideas?
Hello.
This job should be tackled by a facility that has a recovery system regardless of what R fluid your system requires.
If your system has lost all its AC fluid then I personally would remove and replace the compressor along with the rubber o rings to save some money and although you can buy the new refrigerant... I would have it filled and tested for leaks at a shop that has the equipment.
Give your B-friend the gift of a HELM manual for you car and have him go at it. His first repair action may very well pay for the manual. HELM says recovery should be performed by a shop certified to do so, however, gives specs and directions for charging the system with the correct R fluid.
KNLNGUS.
My Sedan had the same problem. A/C compressor was whining / failed so I had a mechanic cut the belt to A/C since it's winter time. Just ordered a new one from Acura of Augusta and will have it installed in the coming week. Good luck.
parts & install is around $900.00.
