First off, if you are LOW on refridgerant,
you have a LEAK - get your system leak checked.
You will just be throwing away $$$ when you "top it up" all the time.
Go to a qualified A/C service shop, not a pep boys or Mienke.
I would agree that you may be low on refridgerant or the triple-pressure switch is on its way out.
Our systems should not cycle very much. Legends (all) use expansion valves not an orfice tube.
what happens is the compressor builds up pressure (by way of the pulley) in order to compress the freon... when the pressure is built up enough it turns off... BUT when there is NO freon... the compressor will turn on and see that it cannot build pressure and then turn off
The compressor does what it's name suggests, it compresses VAPOUR to LIQUID nothing more.
The pulley is always spining, when the clutch is engaged (by the triple-pressure-switch), it (the clutch) pulls on to the pulley and that causes (the internal of the) compressor to spin (ie compress). The expansion valve allows refridgerant to move from semi-liquid state to vapour state into the evaporator. The air in the vents is pushed across the evaporator and the the heat is removed from the air. The now "cool" air is blown thru the vents into the cabin.
It is the expansion valve that creates "pressure" in your system.
Post the HI and LO pressures, vent temps and ambient temp to get a better indication of problems.
Low side is low and high side is low - low refridgerant
Low side is low and high side is high - blockage in system - expansion valve, dryer
Low side is high and high side is low - if guage reading is wild, then compressor failing
Low side high and high side high - over charged
Your LO side line should be very cold and sweaty on a humid day.
Your HI side line should be hot to the touch.
Our system take 24oz of refridgerant and ~8oz of oil. You could be low on one or both.
May be temperature sensor ?
Was the refridgerant charged into a vacuum ?
Hopefully it is just low and you'll just need a refill (once the leak is found and repaired).
