Discussion Starter #1
So I have a 1992 Acura Legend LS. This is my first car (im 17) and overall, ive fixed the alternator, brakes, all things interior and the cooling fans, and the VSS speed sensor. However, my abs light is still on. What should I check first? I’ve thought about replacing the abs pump and/or brain but is there any diagnosis i can do apart from reading the codes? thanks
The ABS system issues can be traced to a lot of things - the pump, pressure switch, the accumulator, modulator and the ABS controller.
Read the codes. What are they telling you? Report back.
Do you know how to get the fault Code?
Greetings
Ralph
I would recommend that you read the car manual that explains this process in great detail.
