is there anyway to seal the leak on my evap core other then a chemical sealer n buying a new one . friend sugested to soder up the leak or jb weld it. what do u guys think ?
You should be able to solder it. Dont use electronic solder with a 60/40 mix. You can pick up some stuff thats a lot thicker but its melting temp is higher so you need a higher wattage iron. Also get flux paste and put it on the hole first. Im not entirley sure how the flux could effect the a/c system, but it cant hurt too bad.
