I'll park my car and then come back to it later and turn it on and the AC isn't working even though it says its on 60 or whatever it is set to...The guys at the Acura dealership said to tap the dash and it will come on and I have and it works. What I want to know is, what is causing this? AC compressor? How much $$$ are we talking here? Should I let it keep on doing this and just live with having to tap the dash or...??? Thanks.
I'm surprised that the guys as acura dealership told you to tap the dash to get the A/C going rather than telling you what the problem was!
If tapping gets the A/C going, I doubt it is the compressor. but in any case, you should either take it to some AC/ electrical shop or some acura specialist. might just a be a loose connection, who knows?
I have a similar problem about a month ago. what happen was when I turn the a/c on it wouldn't not work and I also can not feel the a/c kick in either. So, I play around with the a/c panel and button and it work for awhile. Anyways, what I did was replace the whole a/c unit. I was lucky that my unit is the manual type therefore it was cheaper. I wound it on ebay for less than $20.00. I hope this will help you. Good Luck!!
