1 - 7 of 7 Posts
One place you can take accessory power from is your cigarette lighter. You're only using this source of power to *click* the relay, you're not running the actual fog lights off this source so this source will do. Just take off your centre consol panel to gain access to behind the cigarette lighter under your stereo, and splice into the + wire (there should only be 2 wires going to it, black and another colour, the wire you want to splice IS NOT BLACK).
Hope this helps.
0000$$$$0000####0000
On the G2 Legends at the bottom area of the interior fuse panel is some black spots for accessories. I will try and post a picture later. But anyway, one is for constant BATT, while the other is for ACC power. A fuse needs to be inserted into a black fuse slot for it to work.
1 - 7 of 7 Posts
