Discussion Starter #1
Does someone have this part or know someone who might?
Also, would this part from a later Acura fit my model?
Could this part be repaired, as my mechanic said the housing is leaking?
Discussion Starter #3
Thanks for the info. As it turned out when I couldn't locate this speed sensor for my 1988 Acura Legend, I thought maybe this part was also used on a Honda model. I contacted the seller you list and asked if he had one that was used on a Honda. Yes, he said, so I found the part. He also listed the other one he had in stock.
