1 - 2 of 2 Posts
Now do you mean, when you press the button on the climate control to OFF, the A/C still runs ?
If it runs all the time, could also mean that the A/C relay may need replacing, the triple pressure switch may be shorted or it may be the climate control unit that is failing.
Please be a little more specific with the problem.
ie "the engine is running and the a/c is switched off, but it is still blowing cold air"
What trim level L, LS ?
1 - 2 of 2 Posts
