1 - 2 of 2 Posts
Okay. Got G2 94 Coupe....every time that i balance the headlight with the bubble in between the lines they never stay. help! somebody. This is really bugging me. My light beams all off!
get a philips screw driver... you will see two holes where you can insert it. the outer hole adjustment adjusts the horizontal beams, and the innter hole adjustment adjusts the vertical beams. You should adjust the vertical beams to help level it out.
1 - 2 of 2 Posts
