Adjusting HID
1.6K views 5 replies 5 participants last post by  Saywhat
So I just got my HID light and they seem to be all over the place and not like aiming straight ahead. I don't know if this is because they are too bright for my car, but has anyone had experience with this and can help me out?
And I have a 93 sedan
#3 ·
Lol whoever told you to do a retro fit is just being smart.. If you look down at your headlights from inside the engine bay your gonna see 2 different gears attached. Those are for adjusting with a philips screw driver. One aims up and down, the other aims left and right. Pull up on a **level** surface about 10 feet from a garage door or building, turn on your headlights and using a philips screw driver tune it yourself. VERY easy, just takes a little testing to get it where you like..
#5 ·
With a little patience and correct aiming it will work. Yes its true that the OEM housing is not the best to use for HID lights, but like I said - aim it low and point more towards the middle and you should be ok. I have had my HID in both of my 95 Coupe and Sedan for a year now and I have only been flash 2 times (both times I was going up a hill). So it is tolerable to oncoming driver if you aim it correctly.
