i know that the konis can be adjusted for softness. just loosen the strut bolt and with an allen wrench you can turn and adjust, is turning left for a stiffer ride and right for a softer ride, not sure on that. how do u get it so it is equal on both side? i been trying to figure it out. thanks if anyone knows.
OK, here's how you adjust on Konis:
1. Push the shaft all the way down and hold it there.
2. Turn the shaft counter-clockwise until you engage the adjustment notch.
3. Turn counter-clockwise some more until it stops, when it stops, that means you're at the lowest (softess) position.
4. Turn the shaft clockwise to adjust to your desired firmness.
5. Koni shaft can be turned 2 1/2 turn to get full firmness.
Hope this helps.
If you're trying to do this while they are in the car, you won't get anywhere ... you need to take them out to adjust. I apologize if you already knew this :)
