Hi,
I'm in the process of doing the by-pass inlet pipe repair. I've got the intake off and noticed the air suction pipe where it bolts to the air suction valve is over 50% clogged. The weird part is the blockage almost seems like itls intentional. I don't want to dremel it out unless that's the right thing to do.
Anyone that has removed the intake and air suction pipe, can you tell me if your AS pipe was partially clogged or not? It almost looks like it's by design, but doesn't make any sense. Thanks!
