ok guys i got some probs with my aftermarket alarm system..........
first, if i lock the car using the doorlock button from inside the car....................which activates the oem alarm.............if i come back to my car and press unlock with the remote, then the factory system goes off!!! this is so anoyying because sometimes i forget and accidently turn on the oem alarm or sum1 else does it......
also my alarm system is supposed to automatically lock the doors and arm itself 60 seconds after ignition off and last door has been closed..............but it does it regardless of whether the doors are closed or not!!! this especially sucks because if it gets armed while the door is opened it goes off when the door is shut, because of the shock sensor...............even if u shut it so lightly.............lol
also wen it arms itself that way when the doors are open i THINK it somehow activates the oem alarm too. so then if i use my remote that sets it off too.....................this happens sometimes.....................right now i went to test it.............i opened the door and waited 60 secs and it armed itself with the doors open (not supposed to)..........so then i shut the door and the alarm goes off (shock sensor).................so i shuttoff the alarm with the remote..........and now my oem alarm goes off!!!!!!!!!!!!!
those 3 things, i need to know how to fix.................does anyone or did anyone have any of these problems??? and how do you fix them??? i want to be able to utilize both alarms............but i dont want the oem going off by the remote unlock, if its activated
please help guys!!!
please help guys!!!
