Hey guys and gals....
I have been reading threads for 2 days trying to figure out my problem but unable to pinpoint exactly the problem. My 95 legend LS started acting weird when after disconnecting the battery to clean the cables. After reconnecting the battery cables the alarm came on (no problem right?). The car was already unlocked so I put the key in the ignition hoping that would turn the alarm off....no luck....so i then got out of the car and went to the passenger side and locked all doors then unlocked with the key in the passenger side door. Alarm came on again and since then i have not been able to disarm it and it will not let me start the car. At first i was getting the led lights on the dash and it would not start. I checked all fuses and no fuses are blown. I also tried the instructions posted about using the valet switch. I found a off and on switch hanging from a black/grey wire to the left of steering column. I assumed this was the valet switch, I saw no other switch near the fuse panel. Using this switch as instructed, i thought would work when trying it one time, I put the key in the ignition to the on (ACC) position then flipped the switch to the on position and proceeded to start the car. Within a matter of 2 seconds, the alarm lights stopped flashing and the car was about to start but then went dead. At this point, no led lights, headlights nothing. I then saw a post about disconnecting the brain unit of the alarm system under the dash. Tried this also. After pulling the lower dash down I found the black box and disconnected all connectors, still nothing. I then reconnected all connectors and still nothing. Now when i put the key in the ignition i hear a clicking noise as soon as i put the key in. There is also a clicking noise under the hood from the box next to the battery. I'm lost at this point. Not sure if my battery is totally dead (tried to jump it but no results) or if something else is going on. Help!!!
Sorry for the long post...just wanted to give the full details......
Anthony
Anthony
