1 - 8 of 8 Posts
looks like an open end wrench job to me
Yep, definitely a two open-end wrench job and lots of elbow grease:) . When I changed one on my other car, I had to take the whole thing out to crack the nut. Those suckers are on good because of the high pressure in the fuel line.
Have fun.
Premium Member
Have fun.
That's why I recommended he go to a shop to have it done. not a fun thing to do.
try a breaker bar or find a pipe that will fit over your wrenches. Extra leverage=extra easy!
Whenever you need to remove or install fuel line fittings, you need to use a flare-nut wrench. The line you depicted is supposed to be torqued to 28 lb-ft. Suggest you buy an OEM filter as some aftermarket fail to include all the sealing washers (3).
1 - 8 of 8 Posts
