1 - 7 of 7 Posts
OKay, I need help i checked all the wires and fuses and still no sound out the sub. The power on my amp is still on but my sub still doesnt work. Have a feeling the amp is burned. Any suggesstions? if it is burn how did it burn thanks.
FRISCO LEGEND BABY!!!!
Did you connect everything right? RCA cable connected from stereo to amp?
start off by putting in a spare amp, or a friend's amp in there to see if it works. then go on from there. if it doesn't work either, it's in your wiring somewhere, maybe something loose. check all connections, remote wire, rca wires, speaker wires, power, ground. If it does work with the test amp, then it's your amp. It's fried.
1 - 7 of 7 Posts
