So I've been having a code 12 pop for the past year, but since its gotten cold, its becoming more frequent (like my friggin battery problem). Anyway, I notice it usually triggers a code when I come to a stop from say about 80kmh, under medium to hard braking. So basically, when the rpm's come down to an idle. I cleaned the EGR a few weeks ago, but still get the code.
Keep in mind I have a terrrible hesitation problem, but more on that later.
So I got the car warm and applied vaccum to the EGR. Im using the ol' rental vacuum pump from Canadian tire, and if I pump the hell out of it, I can raise it to rougly 5 (hg?) and I CAN get the motor to bog AND stall. But the vacuum doesn't stay at 5, it slowly comes back down to zero. I've never used a vacuum pump, I was pumpin the thing to hell, but have read it should only take a few pumps to get it to roughly 10?
The book says, does it hold vacuum...well kinda, not much of one. Does it stall the engine? if I pump the out of it...so it says to move on.
So I assume its half assed working? And should just replace it?
I did the rest of the troubleshooting, until the part about hooking up the electrical harness. Everything checked out fine, even applying postive and negative power to the connector on the firewall.
Now my hesitation problem, which I dont think is related to this (who knows) but it occurs a lot. Usually goes something like this, step on the gas, sometimes you get a bog, or bogging, the rpm's climb at a steady rate, but you can just feel the lack of power, once you get to about 2000-2100 rpm's, as if you hit the NOS, the damn thing rockets to 3000rpm and you feel the huge surge of power. Then it shifts, and the power backs off usually and becomes more steady.
You can see how this is not only a pain in the ass driving around, but in the winter, you go from slowly accelerating on ice, to spinning the tires.
Any insight to either problem would be appreciated. I just changed the pcv valve, cap, rotor and will do the plugs this weekend.
Thanks guys.
Thanks guys.
