1 - 2 of 2 Posts
The antenna mast consists of the mast sections to which a plastic toothed cable is attached. If you have two pieces, you have a broken mast/cable assy. and it cannot be repaired.
There is a tutorial re How To install a replacement mast. You should buy a new antenna nut (under $10) as often the old becomes scratched during removal.
Repair works best with two persons; one performing the job and the other turning on the radio to activate the antenna motor to retract the cable into the housing.
1 - 2 of 2 Posts
