Right off the bat, you should know that if the cooling system has not been maintained, your Legend may strike back with a bad headgasket. A checkup at your local Acura dealer would be a smart move. As with any car, the Legend has common failures. Check the Newbie FAQ link in my signature and nearly any question you could come up with is covered. Good luck with that 6 Speed!
