hi,
i got my one piece headlight and the fog light is an H1 bulb. the problem is that the harness only connect positive wire to the bulb while the ground (negative) goes nowhere. there is only one connection to the bulb, not like regular bulb where they have two poles. i connect the bulb to the wiring, but it doesn't light up although the bulb is good.
please shine a light on this. thanks.
no it isn't. the bulb just have one wire and it's the positive wire that goes to the harness.
the harness itself have two wires, yellow and black, but then only the yellow ones that goes to the bulb while the black goes nowhere. i already connect the yellow to positive and the black to negative to my low beam but still not working (the bulb is good though, i check it, no broken filament). probably i dunno how an H1 bulb works.
