I miss understood your original question, but how's this for service. I just went down to my basement and and unscrewed the 6 black screws on the underside of my original armrest lid (1991 LS Sedan automatic). The underside plastic pulls off to expose the 4 screws that hold the lid to the hinges. Remove those 4 screws and you are all set to reupholstered.Well, I'm getting the lid reupholstered - and need to take it off to give to the shop. Was thinking of removing all the screws on the bottom of the lid?
-Ed
:bowdown: :bowdown: :woot:I miss understood your original question, but how's this for service. I just went down to my basement and and unscrewed the 6 black screws on the underside of my original armrest lid (1991 LS Sedan automatic). The underside plastic pulls off to expose the 4 screws that hold the lid to the hinges. Remove those 4 screws and you are all set to reupholstered.
...with that done... FS - a 1991 armrest lid (therefore no cupholder) ready to be reupholstered to any color you want
Good luck.
I do not have all your answers, but here are some...are the Armrest Lids interchangeable between the Sedans and the Coupes, and further, are they interchangeable between the Automatics and the Manuals???
Any enlightenment, or wisdom that could be shared on this would be sincerely appreciated.
Thankyou in advance for any consideration, and especially to Edify for his understanding of the need to ask the question(s).
Thanks, Nowyfe
It still closes, so i mean its not life and death that the magnets dont work. I've had mine like that for about 1.5 years and no one has ever noticed a difference when they open/close my lid.If you replace a non-cupholder lid with one that does, you also have to replace the console box. The magnets are are opposite ends.
When I did this swap, I also had to remove the bolted on metal bracket that attached the underside of my original 1991 console box to the area around the airbag system because the shape of the bottom of the original console box was slightly different than the "newer" cupholder console box I put in.If you replace a non-cupholder lid with one that does, you also have to replace the console box. The magnets are are opposite ends.
"They" may not notice but I do. Fuck what everybody else thinks. Do it right or don't do it, IMO.It still closes, so i mean its not life and death that the magnets dont work. I've had mine like that for about 1.5 years and no one has ever noticed a difference when they open/close my lid.
Good point. One of the braces has a screw point in a different spot than the other. I had to do that as well.When I did this swap, I also had to remove the bolted on metal bracket that attached the underside of my original 1991 console box to the area around the airbag system because the shape of the bottom of the original console box was slightly different than the "newer" cupholder console box I put in.
