I was planning on doing the tranny drain and flush thing. How many litres of Honda Atf do i need to do it 3 times? As well, when putting atf in the crankcase to help get rid of the valve tapping, do i need to use honda atf or can i use ford type f or does it matter?
Thanks!
Check up the DIY- Forums.
All the questions are there.
To answer ur question quickly though, it takes between 3-4 quarts everytime u do the drain and fill.... Honda ATF, do it every oil change.
Easy enough.
C25A1guy said:
What if I do just 1 drain and flush w/ regular dextron???
Dexron is crap.
Use genuine Honda ATF.
Dexron will probably ruin your tranny in the long run.
Honda ATF has special additives that help our Acura/Honda trannies withstand time.
