I've had a few people PM about info. on the auto2manual conversion so I'm putting this thread together with a parts list. I really think that this info. should be on a Sticky even if it's not this particular thread.
As for the ecu I hear you can change it from auto to manual now but I haven't fully read that thread yet. I'm going to put it on the list anyway.
The prices are all average so it could be less or a more. This is for the 6-speed with 5-speed flywheel/clutch. For full 5-speed just get a 5-speed tranny & ecu. For full 6-speed just get 6-speed flywheel/clutch. The parts you need are
1. 6-speed tranny (and fork) $800
2. 5-speed flywheel/flywheel bolts $40/$25
3N. 5-speed clutch kit and pressure plate bolts
4. pedal assembly $30
5. shift linkage & knob $50
6. clutch hydraulic lines and clutch damper $100
7N. clutch master cylinder and reservoir $40/$20
8N. clutch slave cylinder $40
9N. rear tranny mount (three M10 x 1.25 bolts 90/100mm long and three 2.25" bolt spacers or a bunch of washers) $90
10. 5-speed or 6-speed ecu $75
11. 5-speed or 6-speed differential $200
Optional
1. shift knob (aftermarket or new oem)
2. manual shifter console
3. manual gauge cluster
I put an N next to anything that should be new.
That should be it, if anyone sees anything missing feel free to add to the list. A mechanic will charge anywhere from $1200-$1800 to do it for you. If your a DIYer then you won't have to worry about labor costs.
The clutch kit I can't price 'cause that's up to the individual. I suggest doing a search for more info. on that topic price will depend on brand and stage.
For parts check www.Ebay.com and www.car-part.com
For more info. on the swap try Dv8's page www.2slik4u.com and click "projects"
If you want to wire up the reverse lockout (6-speed ecu only) you have to add a relay in the relay box next to the ABS modulator and run wiring to it for the reverse lockout. You run 1 wire from the ecu to the relay through the firewall, then you connect 2 of the other terminals to a 12v+ source. The other terminal sends power to the lockout solenoid when the ecu triggers the relay. The relay is grounded by the ecu when the car travels over 12mph.
-thanks Kenso
Nuetral switch goes into the same spot in the manual ECU as with the auto ECU, so if you wire the M/T nuetral switch into the P/R/N/D4/D3/2/1 switch (shifter console), it will work fine. The reverse light switch doesn't go through the ECU. Check out the "Standalone Engine Management System and ECU Wire/Pin Diagram" for the pin-outs.
-thanks Matt (sr5guy)
Optional
-thanks Kenso
