21 - 28 of 28 Posts
yea, our 4th gear is overdrive. if you look at our gear ratios, 4th gear is OD (on 5 speed, 5th is od). Take it like this with the flow of gear ratios. These numbers are gonna be used to make an exaple.
1st gear: 3:1
2nd gear: 2:1
3rd gear: 1:1
4th gear: .75:1
Overdrive is basically allowing the engine to go through another set of revs at lower then 1 to 1 ratio.
gears not shifting
iv been reading everybodys posts and mine sort of does the same thing it used to hesitate and i gave my car a tune up
plugs wires air filter fuel filter cap and rotor not the tranny fluid yet
but besides the fact
my gears wont even shift anymore even if i put the pedal all the way down and also all of you that have the 1g know what the gear indicators look like
p
r
n
d
s3 s4
2
well it will also say that im in s3 and in d at the same time why why why
it really pisses me off
thanks
jorge
AMSOIL ATF
Dont waste your time and money with the Honda ATF, use the AMSOIL SYNTHETIC ATF, it works miracles. I put it in my Integra and Subaru and I was simply amazed to say the least.
1989 Legend coupe 5-speed 52k miles
1990 Integra automatic 225k miles
1993 Subaru Legacy automatic 203k miles:D
Discussion Starter · #26 ·
Why does everyone say only honda atf then? Im wondering if thats just something acura made up to sell more tranny fluid, which is not cheap at all...
I thought that the Honda OEM stuff was to get you to buy expensive ATF so I never bought the stuff since my manual said Dexron II.
I bought the 89 Legend 3 years old and changed ATF every year and the last five years, I used semi sysnthetic to synthetic thinking I was using the best. My tranny whined and shifted very "positive" with a distinct shift. In the last year, I found out about Honda ATFZ1 and tried it.
After two changes in six months, I have to say the stuff absolutely works well. With the second refill, the tranny is now really quiet ( no more whine) and shifts are smoother. The third change will get rid of the leftover synthetic dexron and I should have the tranny where it should be.
Let's put it this way, the tranny shifts better now than it was when it was 3 years old because of the Honda ATFZ1.
Agreed. I flushed the Legend and Civic in the same weekend and noticed a difference in both cars immediately. Second round of flushing is coming up in 2 weeks or so and I expect both to be smoother still.
21 - 28 of 28 Posts
