The 2 JDM trannys that I used have not given me any trouble. I installed one in my sedan and 1 in a customers car. The customer has not had any complaints and my sedan is doing just fine.Bang&Olufsen DK said:heads up dont buy a used transmission unless you want to rebuild it.
i've gone through two so far, but that's because the first was on its way out when i bought he car, the second was a used transmission with unknown history like most transmissions/engines.
the first died pretty harsh with the original mileage at 242,xxx, the second one died slowly...but this is all because 1. i was a knot-head kid. 2. the transmissions were tired.and 3. faulty cooling system.
Now they will last 300-400k miles if you keep them maintaned and and change the fluid.
mine died from heat. I drove it hard, and the transmission cooler wasn't up to snuff, i believe it was clogged. killed the first and second transmissions. i've since installed a transmission cooler, and had the second transmission rebuilt. i've slowed down alot but i do still get on it every now and again, and it's still going strong.
if you drive vigourously, i figure you should get a secondary transmission cooler, or at the very least, get the cooler cleaned and change your fluid every 30k.
the cost for the transmission rebuild was $1500...
i caught the guy sleeping. he knew about G1s but didn't know about the G2s i kept askin him if he knew that 91 was a G2 second generation, he just was like yea yea...after all was said and done he told me he's going to charge anybody from there on out 2500. And you're right...most people will not even look twice at the Legend.
I've found that there are alot of scared mechanics out there. Fear the Legend
on my transmissions they were tired and the clutches were worn. let alone if a transmission dies and if you get it replaced and dont have the cooler flushed you're basically going to be buying another trans...bang&olufsen dk said:i found this transmission to actually be VERY strong, and very reliable...the ONLY issue is the clutches. the Auto trans on the Legend is built like a manual transmission, i.e. it has no Planetary gear sets, just gear to gear "syncromesh" that operates by activating and releasing clutches on different gear sets. the main fall back of this trans design is honda's clutches.
Thats one brave dude right there. Well, at least I wouldn't attemp to rebuild one without it. :bowdown: He is an experienced rebuilder...Bang&Olufsen DK said:yea,
atleast that's how it went down for me. cooler was ineffective because of the build up of clutch shards.carbon buildup, clutches glazed, it was crazy. all because the cooler wasn't done right.
but anyhoo. if you replace the transmission.
Man i think the guy who rebuilt mine flew by ear. it was completely different for him, and he was confused for a bit, but he felt really confident in the finished product. and he gave me a 1 year warranty with unlimited mileage (normally six months/6,000miles) he was extremely proud of himself
I'm pretty sure Level Ten sells the "rebuild" packages for the MPYA. and it's not 1000 dollars. infact i've seen a bunch of trans rebuild packages several years ago and one was a revised version of the one for the MPYA in the TL. *does a search on google*
