Before I install this cihp, I'm curious to know exactly what it does.
Does it ONLY change your air/fuel mappings?
What other changes does it do? Any rev limitor changes?
Reason I'm concerned is because I"m thinking of also getting an APEXi SAFC which allows unlimited freedom in respect to changing the air/fuel mappings around. I'm concerend that both of these upgrades duplicate each other and it'll be a waste to have both of these upgrades.
Is there any advantage to running both at the same time or will a properly tuned SAFC do the same affect as a Stage II upgrade, if not, better as you can really fine tune it while you're on a dyno.
Is anyone running both?
Any info would greatly be appreciated.
