neuspeed has Axis Metal master pads and I just ordered EBC green stuff pads. That's all that I know of.
It is sort of specific, but sort of universal. The rear brake pad size and shape is the same as many other Honda Acura cars, however, some (Like Guy mentioned in his fix topic) use caliper handbrake systems, but we use drum hand brake systems. I don't believe EBC knows of this. The pads however fits perfect as far as size goes over the stock rotor, however, in my case only, when I put them on with my brand new brembo rotors, the entire set up was about 1 mm too thick so I couldn't get the capiler to slide back on if I used all 4 brake shims. In my case, I used 1 shim on each pad instead of 2 and it went on. It could just be my set up though, as I don't recal anyone else mentioning this problem. Maybe I just didn't get the caliper piston pushed back 100%, even though I thought I did.Edub said:G Rahn,
Thanks for the info! I wonder if the EBC pads are specific for our cars... and not universal... The reason I say that is we should not have to modify the pads to fit our cars...
but if those pads are as good as everyone states.. then i think it is worth it to invest and modify them...
Would you happen to have any pics of the pads modified?
thanks!
Eric
Everyone else: Thank you for your input!!!!!!!!!!!!!!!!!
I had the same problem with my front pads. I think that it was the plating that made the difference. I remedied it by sanding the pads down to clear the rotors.ChrisK said:
Aside from that, I'm very happy with them. Like I said, no warm up time at all, and it graps well.
The shims are already on the OEM pad. It simply slips right off. The Legend had 2 shims for each pad front and rear. I presume it is for head absorbtion, but I'm not sure. My other Acura (Integra, if I recall correctly) only had 1 shim, but I can't be sure. Either way, I've been driving with this set up for over one month with no problems, and infact much better braking over stock. Also, like I mentioned, it could be that I just wasn't able to get my caliper piston back in 100%, as I don't recall anyone else mentioning this problem. Also, I put the EBC on my 95 with stock rotors and it slip on perfectly fine. It was only with the Brembo drilled rotors and new EBC pads on my 93 that I ran in to that slight problem. I did use brake quiet, but I really don't think it was needed, as I know others who have not used it and still have to squeek. I just did it because I had a couple of extra packets, and I didn't want to take any chances.Edub said:Chris,
Do the new shims come with the pads? Or should I get new ones from the Dealer? also, how do we know how many shims really need to be put on each side for the front and the rears?
also., did you use "brake Quiet" too?
Eric
