1 - 16 of 16 Posts
Hey peeps-
what is the best grade of motor oil for the legend....I have the 86 legend sedan.....157mi......
WOW....5W-30?....I read that somewhere elso also.....if that's the best...that's what I will get.
Thanks!
I use 5-30 or 10-30. I have been using synthetics for about a year or two. Just found 5 gallons of mobil one synth 10-30 for 12 buks at wal mart. Its says it claims to be formulated for higher milage engines. So I figured of trying it over the 5-30 which said for newer engines, I believe 10-30 is better during summer time anyway and on old oil seals. But 5-30 claims a better fuel economy although I haver never noticed it.
HMMMM......JESS....i kiind of had that same theory as well...my car has 158k and is 16yrs old...10-30W could be the safe way to go.
i'm wondering if i can use 5w-30 for the summer or the whole year? becuase since my recent oil change to 10w-30 my ticking noise seems to have increased but i was told to use 10w-30 for the summer time though:confused: i heard that 10w is thicker so the sun won't thin out the oil during the summer and if i use 5w it will just make the oil very thin and would splash around. i use mobil1 synthetic and wonder if i can use 5w the whole year, i have high milage as well
Why use 5W-30 in a G1?
According to the charts in the shop and owner's manuals, 5w-30 should be used when the outside temperature is 30 F and below.
The link (chart) is right out of the owner's manual. 10w-30 would be more appropriate for warmer climates.
Re: Why use 5W-30 in a G1?
are you sure it isn't for 30 C and below? My manual says 5W-30 is recommended for most climates and 10W-30 for cooler temps...
yeah i thought our engines called for 5w30. thats what i use, and i also put in that valvoline synthetic mix, u just add to your oil and it makes it more durable and lubricates the engine better.
Re: Re: Why use 5W-30 in a G1?
Look at the chart again. The temperature scale is in both F and C. 5w-30 is for outside temperatures of about 30 degrees F and below.
Again, this chart is directly out of the '87 coupe owner's manual. The same chart appears in the '87 coupe factory shop manual as well.
No, this isn' t the chart for the manual transmission.
Re: Re: Re: Why use 5W-30 in a G1?
Both my 89 and 90 owner's manuals say "5W-30 (recommended)". It goes on to list all other grades on a similar scale, though I recall that 5W-30 was in a higher temperature range or something. I'll check it tomorrow.
OK, looking at the chart in my owners manual, i am seeing the chart and 10W-30 is recommended for -10 C and higher climates, below that there is the 5W-30 bar that says preferred and reaches throughout the entire temperature range on the chart to go below -30 C (-20 F) and extend beyond 40 C (100+ F). so it all must depend on which year your legend is since there is a discrepency among paulo's 87 and my 90.
1 - 16 of 16 Posts
