what kind of motor oil should be used for a higher mileage, 5 speed coupe? i need somethin good for the gears, cause sometimes the gears grind when shifting from 2nd to 3rd?? thanks.
Redline MTL or Honda Manual trans fluid works best.
Redline may help those synchros better than honda stuff - also one thing that I found has helped to smooth out the action of the shifter was to put some high temp lube on the ball joint at the bottom of the shift lever (know what I'm talking about?) and on the linkage.
