I’m going to be replacing my brake lines and replace the fluid with Motul on my G1 soon and I’m looking for some advice.
My concern is the ABS system, does the fluid in the ABS mix with the fluid in regular braking system?
If so, when I pump all the fluid out of the regular system will it pump the fluid out the ABS as well? Or do I have flush the ABS separately?
The reason I’m asking is that I don’t want the Motul fluid mixing with the ABS fluid.
Any advice would be VERY much appreciated, thanks!!!!!!
