My right rear brake caliper ('89L) was freezing (which sucks since I had 2 loaded rear calipers installed last brake job) so I had to have it replaced. I also had him replace the pads all around since all were pretty low. After the install, he bled the one right rear wheel but the brake peddle never got firm again. He clamped/cutoff the replaced cylinder but still the peddle was soft. There are no signs of leaks anywhere so of course the next guess is a faulty master cylinder. (The car has 204K and the master cylinder was replaced once before at 75K.) I suggested maybe try bleeding all wheels but the mechanic was certain the work in one wheel wouldn't put air in other parts of the system. When I asked for ideas how the work done might lead to a failed master cylinder he speculated that when the calipers are compressed to load the new pads, you could push "gunk" back into the master cylinder valves, damaging them. That explanation seems to be stretching it a bit.
Does this seem plausible to others? Anyone have ideas on what else to try before plunking $200-300 for a new master cylinder.
