1 - 6 of 6 Posts
New here... bear with me. Recently red brake light is on in my 91 coupe...also after driving for a few seconds, the ABS light comes on. brakes were recently serviced. Any suggestions as to why they come on and how to make them go off?
Check your brake fluid level. My brake light would come on, especially during hard Gforces, before I topped it off. My ABS light never came on, so this might not apply to you. Hope it helps!
Later!
Lee
FIXED..thanks
Thanks..........it was the brake fluid....I was low in one reservoir. Filled it up and both brake and ABS light do NOT come on anymore.
LegendGRL27 said:
ive got the same problem with both lights turning on. which two resevior things do i fill up????????????????
If you open your hood, there is a ABS brake reservoir in the back left hand corner (with a gray cap). The other one located in the back right corner. It also has a gray cap on it. ( If your car is a stick shift, you will see two reservoirs in the back right corner with gray caps sitting side by side. The brake reservior is the left one. It has a wire attached to it.)
yes, same as above....i have a 91 automatic coupe...
one res is located in the left hand corner (gray top)...and the other is in the right hand corner (sitting on top master cylinder) I topped off both of them and brake and ABS no longer come on.
1 - 6 of 6 Posts
