A few weeks ago, my horn, transmission lock soleniod, and brake lights stopped working.
I checked the fuses under the hood and noticed blown fuse and so replaced.
Everything was well for one week, then fuse blows again so I replaced it. Now, fuse is fine, and my left side brake lights are ok but my right side brake lights along with rear window brake light are no longer on when brakes are applied.
My horn and transmission lock solenoid under center console still works.
Does anyone know what this problem might be? Thanks in advance. By the way, car is 90 legend coupe. :confused:
Yes, I changed both bulbs. When I took out one bulb, the 2 lead contact points almost melted into the socket. Anyhow, I did change the bulb and it still didn't work.
I even used a circuit tester to check for juice and found there was none flowing through to the socket. The rear left light socket has juice but the rear right light socket has no juice.
Any comment on where I can check for circuit break would be appreciated.
Thanks.
