Read the LINK and all I can say is that the info is for the Baer co. promotional
efforts. Interesting, but mostly it will be of little value to the novice or young drivers and the common folk. You will note that the " seasoning " process is directed towards " racers ". For the rest of us, well, we install, or have installed, new brake parts and do a few brake pedal applications driving down the street, and call the job done if the car stops normally.
Insofar as calling the ABS an intereference system, my choice of words, I call it that because that is actually what is happening. There is a misconception generally about ABS in the sense that folks think it will assist in brake application or add more braking force to the wheels and of course it does not. My comments were not intended for the folks who know ALL there is to know about brakes, but to the unknowing, in words that I think are understandable. Of course if anyone is really interested in how any ABS system works
www.howstuffworks.com is a good site for easy to understand info on, well, how stuff works, and is just a click away. Personally I obtained a service manual and did a thorough read on the Acura ABS since I do have that yellow light nagging me. Never having had a car eqiupped with such a device I wanted to learn all about this system.
As far as the original poster is concerned, my best guess, with the info provided, is that there is something wrong with the wheel calipers.
There is mentioned and recommending bench bleeding. I do not, and never have done bench bleeding. First off when replacing the MC, even after bench bleeding it, there will be some air introduced in the lines during the process. I install everything as it should be and bleed the entire system afterwards. Works for me and I ALWAYS have good brakes.
I hope the original poster is not all confused by this time and has found some help here.
RAP
