eric76mi said:
when I hit my breaks they feel soft until I pump them. Now I know that it means that they need to be bleed(or so I think) I havent bleed breaks in about 10 years so can I get a little help?
Here is what I would do as a start.
Frist I would go ahead and get some new brake pads and rotors since it would be very easy to install them while doing this and help you out greatly.
1) get all 4 wheels of the car off the ground and the wheels off.
At this piont all you need is a basic socket set, 6" C clamp, and an impact screwdriver to change the pads and rotors.
2) Drain out your brake resivour.
3) Fill the resivour with new fluid.
4) Get an empty bottle and a clear hose that will fit the bleader valve.
5) Get a wrench around the bleader valve and then put the clear tube on and put the other end in the empty bottle.
6) Get someone to push the brake pedal down. Then open the bleader valve. When the fluid stops tighten the valve and tell the other person to let off the brakes. Once the pedall is all the way up repeat. Keep going until you see only clear fluid, and no air, in the clear line. Make sure to start at the rear drivers wheel, then the rear passenger wheel, then the front pass wheel, and finally the front drivers wheel. Also make sure you check the fluid in the resivour to keep it full. If you ever let the resivour go empty, or the person releases the brakes before you have closed the bleeder valve, you have to start all over.
If this does not fix your problem you have a serious leek in your breaking system.
Later!
Lee
