1 - 7 of 7 Posts
Check out how close the LED's match the HID's. Bumper lights are on when parking/lights are. JDM corner lights are now the blinkers... Is it legal? Probably not...we'll see.
How hard is the relay to put in? Would you have to have a relay if you put LED's in te other turn signals?
It's not a relay...it wires directly in where the bulb used to be. It puts the same "load" on the circuit so that the flashers don't think a bulb is out and flash normal speed. Yes, if you put LED's in you will need these or your blinkers will flash twice as fast.
1 - 7 of 7 Posts
