1 - 8 of 8 Posts
Is it possible to transplant a c27a into a 1987 sedan 5 speed? if yes would you have to get a new ecu and a different transmission too?
because i can.
Absolutely possible...
Youd need the engine (duh), ECU, Igniter Unit, and Vacuum box...
Theres some wiring involved but its should be fairly simple and straightforward.
Also helps that you have a 5 speed as the auto trannys ARE different....
whats a vacuum box?
FRISCO LEGEND BABY!!!!
The one circled is the vacuum box:
because i can.
^ yeah the 5 speed would be the best bet since the 2.5 Auto needs a signal from the 2.5 ECU for lockup....so you COULD keep a 2.5 auto, but it may never lockup :sadwavey:
A 2.7 auto could theoretically be swapped in too so long as you wired up the TCU as well...
hoow much does a an ecu, vacuum box, and an igniter unit usually cost?
You can go to the junkyard and pull them out from there. Look for a 88-90 Legend.
1 - 8 of 8 Posts
