Very helpful...thanks. :sleeping:Why don't you just check them and stop being lazy???
-Matt
Yes.I was just curious if my symptoms were typical of cam gears being out of time. [Hint: my symptoms are in white in my 2nd post.]
Well its obvious that you suspected them being out of timing for a reason(maybe cause you fucked up the timing belt job?). It takes me less than 10 minutes to check the timing on a Legend, stop bitching and go grab your 10mm and a 19 mm and do the damn thing.Very helpful...thanks. :sleeping:
