Member
Any of you fellas have any idea how to correct a problem with rear wheel camber adjusts. I have some fairly new Bridgestone re71s on some Konig 17" and I was under the car the other day and noticed extreme wear on the far inside tread. Help...I know I am gonna have to get some new ones but I can't have it happen again. Any ideas?
Is your car lowered? if not there shouldn't be any camber wear, especially for only 17in rims
Member
camber adjust
Nope...not lowered at all. could it be because of a faulty suspension component in the rear? Since I bought it I have done nothing with the rear suspension.
camber adjust
I had that same problem. My tires were wearing out in like 8 thousand miles and just on the inside.
I tired everything to fix it and nothing worked. I finally figured out it was the springs sagging when I had people in the back, that caused the camber to be off and wear.
I fixed it by getting new springs and struts. I got ebach pro kit and koni struts. It wears alot better now even though my car is an inch lower.
I measured my car after I lowerd it and it only lowered half an inch because my springs were sagging so much.
92 legend
