It is easy. You need to remove a total of 14 screws and bolts. You need to remove the phillips screws holding the foglight cover in place. One on each cover (total two). Then you remove the bumper turn signal by loosening the two phillips screws holding it it in. One for each light (two total, running total of 4). Then you remove the 4 10mm bolts from the under side plastic shield. Two on each side (total 4, running total 8). Then you unscrew the two plastic screws toward the center part of that plastic shield. Two total, running total 10). Now, you remove the 4 12mm bolts holding the bumper in place. These are accessed through the hole left from the bumper turn signal. (4 total, running total 12) For the Coupe, there is only 2 12mm bolts holding up the bumper, so the total would be 12 bolts.
Now, if you are going to paint, you now have to remove all those plastic screws that hold the bumper cover onto the bumper itself.
After you get used to removing the front bumper, you can pretty much do it in 5 minutes.
