This is NOT carfax...but consumer reports version. It found 7 records.
Vehicle Snapshot Vehicle History Checklist
Vehicle
1995 Acura Legend GS
VIN
JH4KA7688SC003689
Body Style
4 Dr Sedan
Country of Manufacture
Japan Review the Vehicle History Records below for details on the following potential problem areas with this vehicle:
Potential
Problem Areas Records
Found?
Lemon? No
Odometer Irregularities? No
Major Damage? No
High-Use or Lease? No
Emission Problems? No
Safety Problems? No
Stolen Vehicle? No
Other History? No
We have searched our database of insurance, DMV, and auto auction information and found the following 7 records for this 1995 Acura Legend GS. Note the highlighted rows for potential issues that could affect the value of this vehicle.
Date Location Mileage Description
1994-11-21 KAILUA, HI 6086 Title
1996-05-13 HONOLULU, HI Odometer Reading from Auto Dealer
1997-09-25 KAILUA, HI Renewal
1998-10-05 KAILUA, HI Renewal
1999-09-28 KAILUA, HI Renewal
2000-09-25 KAILUA, HI Renewal
2001-06-19 DALLAS, TX 32852 Passed Emission Inspection
Glossary of Descriptions Found for This Vehicle (full glossary)
Description Full Definition
Title Vehicle had title registration event reported by state DMV.
Odometer Reading from Auto Dealer Odometer reading was provided by an independent source from an auto dealer.
Renewal Vehicle had registration renewal event reported by state DMV.
Passed Emission Inspection Vehicle passed the state emission inspection.
Highlights from our Editors' Review of the 1995 Acura Legend
The following summary includes recall and trouble spot information for several model years of this vehicle. Only information labeled "1995" applies to this vehicle.
Consumer Guide Rating
Best Buy
Pros
Antilock brakes
Steering/handling
Passenger and cargo room
Instruments/controls
Acceleration
Cons
Automatic transmission performance
Fuel economy
Rear-seat room (coupe)
Road Test Scores
Performance Not Rated
Economy Not Rated
Ride Not Rated
Noise Not Rated
Comfort Not Rated
Cargo Not Rated
(all scores out of 5)
NHTSA Safety Ratings
Front Impact, Driver Side Safety 3
Front Impact, Passenger Side Safety 4
Recalls
Check with the seller to ensure that the recall work was completed on these items.
Trouble Spots
Check for these possible problems when test-driving and inspecting this vehicle.
Steering problems: Steering may be difficult during parking maneuvers due to a problem with the vehicle speed sensor in the power steering unit. (1991-94)
Steering problems: The vehicle speed sensor (VSS) tends to fail but a repair kit has been released so that the whole power steering assembly need not be replaced. (1991-94)
Steering noise: Telescopic steering columns may groan when the wheel is turned because there is not enough lubrication on the column.
Security alarm: The security alarm may not deactivate with the key in the driver's door, which sets off the alarm. Turning the key again may disarm it.
Poor transmission shift: Debris collects on the screen in the engine's air intake causing poor acceleration (all models) or lack of upshift (automatic transmission) at full throttle. (1991-94)
Engine noise: Carbon buildup on the piston rings may cause piston slap. The fix is to clean the carbon using GM Top Engine Cleaner sucked in by way of a vacuum port on the throttle body.
Cruise control: The cruise control may not engage on 1994 models due to a faulty actuator.
Repair Costs
Wondering what it will cost to fix this car if something goes wrong? Here are some commonly repaired items on all cars and how much it would cost to fix each item on a 1995 Acura Legend. (Note: this information is general and does not represent repairs that the specific vehicle listed may require.)
Commonly Repaired Item Typical
Replacement
Cost
Timing Chain or Belt $300
Shocks and/or Struts $895
Radiator $530
Exhaust System $810
Constant Velocity Joints $555
Clutch, Pressure Plate, Bearing $965
Brakes $200
Automatic Transmission or Transaxle $1005
Alternator $360
A/C Compressor $715
Important Disclaimers
While Consumer Guide® makes every effort to present complete and accurate information, a Consumer Guide® Auto Check is not a guarantee of the quality of any used vehicle. There could be other problems with this vehicle that have not been reported to Consumer Guide® or Experian. Please read our full disclaimer.
