I have had my alpine cd changer for four years and now every time I hit a bump it skips.
Is there any way to clean it or should I take it to good guys and let them clean it.
I tired on of those cds you play though it to clean it and it didn't really work
I like shiny
We had the same problem in my Mom's 94 L Sedan. At first we thought it was the cds I made, I made all new and used some originals-still skipped. My dad took it to car toys to get it cleaned. All they did was use one of the cleaning cds you are talking about. My dad finally got fed up and just bought new, that is what you might have to do. :( :)
Senior Member
check your dampening positions...
When I first installed my alpine chms620, it skipped on every little bump. So i took it out to return it when i noticed that there were TWO shock absorber setting on the changer - i had originally only set one side for vertical dampening. After I switched both switches to vertical dampening (mine's installed in the factory location), all skipping problems stopped. Not sure if this is your problem, but if it is, its an easy fix.
