I recently noticed that two center headlights on my 88L sedan did not come on. These lights are clear colored, about 4"x6" size, next to the outter headlights. What are these two lights called? fog lights? I could not find the fuse for them. Anyone knows how to fix it? It seems that I got both high and low beams in the outter headlights.
These are not original equipment lights ...so a previous owner must have installed them ...likely as "fog" lights. They may have been wired to an existing fuse, or maybe to a separate fuse and under-dash toggle switch of some kind. Do a bit of detective work ...follow the wires ....check for a burned out fuse, or disconnected wire, etc.
