HERE IS THE STUFF FOR YOUR KICKER L7's
GO FOR SEALED ENCLOSURE>>>>>>>>>>>>>>>>
The original round Solo-Baric® was the world's first small-box sub, and it started a trend in speaker design that others are still trying to imitate. The bar is raised even higher with the new KICKER Solo-Baric L7, the world's first square subwoofer. Its radical design reshaped the way the world looks at subwoofers. And once you experience the Solo-Baric's titanic bass for yourself, you'll never look at subwoofers in the same way either. You don't have to be a rocket scientist to see that the Solo-Baric L7 is different from anything else in the car stereo universe. But why square? It's really pretty simple - the area of a square is greater than the area of a circle with the same width. By making the Solo-Baric square, KICKER gives you the most possible cone area (or Sd) for a given size baffle - 16% to 20% more cone area. And more cone area means the Solo-Baric L7 moves more air. The ultra-length voice coils and hyper-extended pole pieces mean 24% to 49% more excursion (Xmax) than previous models. That means the new S10L7's output capability is a staggering 78% greater than the previous S10d model. It's like buying one size subwoofer and getting the output of the next bigger size.
KICKER's revolutionary L7 subwoofer has been totally improved this year and features performance improvements for increased output. Upgrades include increased Xmax, improved multi-layer voice coil and Kapton former, larger and more compliant surround, a cutting-edge titanium deposit on the beefed up cone, redesigned cast aluminum basket, and coated tinsel leads.
The Solo-Baric L7 has greater power handling and more resistance to abuse than any subwoofer KICKER's ever made. All models have dual voice coils for ultimate wiring flexibility - 2-Ohm DVC models let you run at 1 or 4 Ohms, 4-Ohm DVC models allow 2-Ohm or 8-Ohm operation.
Features:
Unique Square Cone Design
Cast Aluminum Basket
Double-Stitched Santoprene Rubber Surround
Nickel-Plated Connection Terminals
Titanium Deposited Cross-Ribbed, Advanced Composite Cone
Inverted Structural Dome (ISD) Dust Cap
Multi-Layer Voice Coil with Kapton Former
Perimeter Venting Cooling System
Impregnated Cotton Spider
Extended, Bumped, and Vented UniPlate Pole Piece
Optional Patented KICKER Grille
Subwoofer Specifications
Rec. Sealed Box Dims: 0.88 - 2.00 cu.ft.
Rec. Ported Box Dims: 1.75 - 3.25 cu.ft.
Free Air Usage: not recommended
Sensitivity: 86.9 dB
Frequency Response: 20-100 Hz
Recommended RMS Power: 750W
Peak Power Handling: 1500W
Impedance: Dual 4 ohms
Shipping Weight: 20 lbs
Warranty: 1 year
