if you want to flush the motor use a lil trans mission fluid. b4 you next oil change
how much should i use? like a ratio. dont want to over do it.if you want to flush the motor use a lil trans mission fluid. b4 you next oil change
JDMKang...and what does that do? Does it clean everything out releasing any gunk? Also, how long do you want to run it like that?1/4 would do just fine.
