What's the process for changing the tranny oil on the G2?
The G1 was fairly simple and had a drain bolt, much like the one on the Engine. However, I noticed the manual doesn't mention how to change it, is it a pan? Much harder that way, hehe
(Automatic by the way)
***Im pretty sure its 3/8 but if not its 1/2 inch****
The plug is located on the right side (passenger) of the pan. It requires a 3/8 drive socket wrench. Its easier to remove using a 3/8 torque wrench, you get more leverage.
